Page 1 of 9 1 2 3 ... LastLast
Results 1 to 10 of 152
Thread: Parts List Thread
    Sharkie's Avatar
    Dec 2004
    Default Parts List Thread
    Okay guys and girls I'm creating this thread to help us with parts that we need for your cars
    so here the first one:
    Timing belt kit:
    This Kit is from dayco part number is KTB099H.
    Product details for: KTBA099H
    View Applications for KTBA099H
    Description:Timing belt kit (inc Hyd Tensioner)
    Contents:
    94807 Timing belt
    HAT01 Hydraulic Automatic Tensioner (Timing)
    KI16 Timing belt kit idler
    KS22 Timing belt kit seal
    KT53 Timing belt kit tensioner
    price will range for $400- $430 depending where you buy it from
    you can check on www.dayco.com.au and just register to check out the part numbers.
    If you want to add a part number feel free to add follow the same format as I have done but there is to be no spamming here
    Cheers Mark
    Default K&N Panel Filter
    33-2151 K&N replacement Panel filter for 3rd gen Magna/Diamante
    Right! Time to clear this up. My name is Aaron. Marty Monstabishi is my car's name. Why does he have a boys name? 'Cos he's quite clearly A BOY! He's got BALLZ!!
    Happy Sharkie??
    mysti's Avatar
    Jul 2004
    Genuine Mitsubishi Verada KH Xi Chrome Grill (Fits TE-TH, KE-KH)
    MR908341 (was around $190 retail)
    Genuine Mitsubishi Chrome Boot Garnish ("MAGNA" engraved) to fit TE-TH, KE-KH Sedans
    MR907591 (was around $80 retail)
    Gettin' NSW Members Out On Cruises Since 2004.
    Overthrown as NSW Rep in 2008.
    Citizen Insane's Avatar
    Aug 2006
    380 Side indicator assembly (Suit TR-TJ) with amber globes.
    MN169192 $10.45 each (= $20.90 the pair)
    1996 Nissan Skyline Series II ECR33 GTS-T
    '88 EA Fairmont Ghia 5spd Manual - Retired
    '98 TF Executive 5spd Manual - Written off
    Dec 2004
    Default Gates Timing Tensioner Kit
    part No VKMA95040S
    1 x Belt
    2 x Pulleys
    3 x Oil Seals
    cost $165.00
    Autobarn 20% off Sale
    beep beep Ford fella's Avatar
    Jan 2005
    just to add to the gates timing kit, if you want the hydraulic tensioner add h to the end of the part number
    AMC /////// QMD
    bushman's Avatar
    Sep 2007
    Quote Originally Posted by Marty_Monstabishi
    Without looking at this thread i was told that KN didn't stock a filter for TL TW as it's Ryco equivilant is A1514 @ $38.65 but i also have a TH which has a A1359 @ $40.35. Looked at them both, cannot see any difference so have ordered the KN33-2151 for $76.70. If that is a good price i can always get them at that, if not well it will pay for itself after a couple of services anyway.
    bushman's Avatar
    Sep 2007
    Default excel starter motor for !st Gen
    My brother is using a 1st gen starter in his hyundai excel. looks chunckier than excel however the reverse could be done if in a bynd. very cheap at that realy cheap auto joint
    Articuno's Avatar
    Apr 2004
    Quote Originally Posted by bushman
    TE - TW can all use the same filter.
    MagnaByDesign's Avatar
    Jan 2007
    Default Side strips
    For all those that asked about the side strips on D-Vans car, here are the numbers.
    These are for chromed/primed parts. You will need to get them painted to suit your car colour. MMAL dont stock them coloured.
    MOULDING FRT FENDER LH/RH MR929825/6
    MOULDING FRT DOOR LH/RH MR929827/8
    MOULDING RR DOOR LH/RH MR929829/30
    MMAL has plenty of stock, but its not cheap .
